leaks
45
Oday 22 sunset bay new york
after a good rain i get water in cabin which requires me to pump bilge, moisture on starboard sette bunk any other owners of 1975 oday 22 experience this and where would the first place to look be?? the ports, the deck plates, stanchions any advice greatly appreciated. hey its almost time to get to yard and so some maintenace. it warmed up to 30 degrees today
A
Adam
Two main suspects for leaks
Check your portlights, as the boats age, the caulking/packing the windows came with dry out. Not that hard to remove them and either reform the caulking material to get a better seal, or get new cauling material. The other main suspect is your stanchion thru-bolts. If there is no bedding, any rubber gaskets, or small stress cracks, water will find its way in. This will then run down the inside of the hull, under the settees and into the bilge. Re-bed them with 4200 should solve the problem. Good luck, Adam
Jan 24, 2005
4,881
Oday 222 Dighton, Ma.
The gunwale strip is the first thing you should check before you do anything. If you've never had the gunwales off and re caulked under it, now is the time to do it. The caulking under this strip usually lasts about 10 years. Just take part of the gunwale off at a time, clean up the surface under it, and apply a regular boat caulking like Boat Life or 3M. Then re-install that half of the gunwale and take the rest of the gunwale off until it's done. If the leak persists, you can narrow it down a lot easier and find it faster. My guess is; it's probably seeping through a screw hole under the gunwale. Keep in mind that some hull cleaners out on the market can eat out caulking.
Dec 5, 2006
45
time for work
thanx joe and adam guess ill have something to keep me busy this spring
