Just curious on how best to seal the toe rails and hand rails. Also, I bought 2 new teak hand rails that are not stock but very close. How would you best install them, since they are straight and need to bend in an ark to line up with the holes.
The first wood screw on one of my toe rails on my O'Day 222 popped up last year and the bung had come out. As a result it caused a leak in that small section of the bow behind that little bulkhead in the V birth section of the boat. I had no idea that it was leaking at the time becuse I had a hooded sweat shirt in there that I hadn't touched in a while until I went to grab it one day and discovered it was soaking wet. To make a long story short though, I was able to stop the leak without removing the whole toe rail by using a screw driver to prop it up enough to slide a Popsicle stick between the Teak and the deck with some 3-M 5200 on it.Just curious on how best to seal the toe rails and hand rails. Also, I bought 2 new teak hand rails that are not stock but very close. How would you best install them, since they are straight and need to bend in an ark to line up with the holes.
Do not use 5200. The stuff is permanent to gel coat and fiber glass. If you have to repair again, it is major hassle.If they are about the same size then they should bend enough as you line up and install a screw one at a time.
Rich
whereas that it is true the 3-M 5200 is a stronger adhesive than the 3-M 4200 and the fast cure 4000 which is my favorite adhesive caulking, if my toe rail had been adhered to the deck with the 3-M 5200, it may have never popped up and it's possible that I would have never have had to reattach it back in the first place.Just curious on how best to seal the toe rails and hand rails. Also, I bought 2 new teak hand rails that are not stock but very close. How would you best install them, since they are straight and need to bend in an ark to line up with the holes.
"This old boat" shows a toe rail being installed to curvature by using a block to pull the trailing edge of the toe rail into line with the curve while gluing and screwing. I think my first try, when I try, will be to take my old one off, use it to make a jig, then employ Capt. joes' steam chamber method. As for a jig, possibly try using peg board and pegs, which would allow adjustments and multiple steamings?RBone said:If they are about the same size then they should bend enough as you line up and install a screw one at a time.
Rich
Thanks bob, sounds great. I'm going to mill my own toe rails from plank. About how thick were the new toe rails?adirondackbob said:When I replaced the toe rails on my 1983 O'Day 23, I asked Rudy at D&R Marine (from whom I bought the toe rails) for advice. He suggested drilling the holes using the old toe rails as templates and then installing the new ones from the middle out toward the ends. I followed that advice and it worked very well. I began by screwing in the middle screw for each toe rail (there were four)--after putting caulking on first (I used fast cure 4000). Then I would screw in the next screw forward followed by the next screw aft--and so on, until I came to the last screw at each end of the toe rail. What I found was that the rail was easy to bend in the way. I didn't have to steam the rails to get them to bend, although I did this on a warm, sunny day when the temperature was near 80.
By the way, when I rebed my grab rails, I used the old ones, so I don't have advice about bending those. They're obviously much thicker than the toe rails.
Good luck.
Bob
Interesting thread. I am actually in the middle of replacing my handrails. The advice I was given by my local WM was to use the 5200 adhesive, but now I'm starting to second-guess myself. He mentioned that if you ever try to remove 5200, you will destroy the teak and/or fiberglass. Has anyone here personally tried this method of removal? (disclaimer: I don't plan on removing the handrails, per se, but the fact that I have to replace them proves that they will not outlast the boat)whereas that it is true the 3-M 5200 is a stronger adhesive than the 3-M 4200 and the fast cure 4000 which is my favorite adhesive caulking, if my toe rail had been adhered to the deck with the 3-M 5200, it may have never popped up and it's possible that I would have never have had to reattach it back in the first place.
Last year as I had mentioned in previous threads, I hit a red buoy on the river which was "my bad," and I believe that this bang on the bow of my boat was the direct cause of my toe rail popping out which created a leak through the screw hole in the fiberglass.
If by chance you ever need to remove a toe rail or even centerboard keel wedges that have been adhered with any of the above caulkings, you can use heat from a hair drier coupled with a heated putty knife blade from a torch. It's no different than the techniques used by luthiers in removing the necks from guitars which are adhered with various types of hyde glues.
I understood the need Rich when I reached for my pull-over hooded sweatshirt and discovered that it was soaking wet. I'd have never known that I had water coming in from under the toe rail in the bow. I seldom ever put my hand in that little cubby hole. If left unattended for any length of time my boat would have core rot on the forward deck.I don't understand the need for a permanent adhesive for the handrails or toe rails or for any replaceable part on the boat. Another possibility is Butyl tape. I've been using it since reading about on the 'Ask All Sailors' forum, with good results.
Rich
