Finally after 2 yrs have the boat w/no leaks. When we bought the boat, it had many leaks. Fixed most of them, but after being out on the boat for 2 mos finally got them all (I know, it doesn't last forever). I finally adjusted the NFM ports so they don't leak, what a pain. Two of the Gray ports still leaked and I fixed them by caulking & tightening the screws. I'm probably going to replace the little Gray ports w/NFM so all ports are the same. The most difficult to find was the leak resulting in water on the galley floor. Hunter put wood boxes in cabinets to cover wiring and plumbing. There was a box in the cabinet behind the galley stove that covered the deck drain on the SB side. I removed the box and found the deck drain was leaking and water running down behind the back of the cabinet. Replaced the deck drain w/new one from West and also replaced the hose that was kinked and not draining good. Now no leak.
