leaking water tank outlet
Brad Jones
My 1985 O'day 26 has a 15 gallon poly water tank built-in. The outlet fitting (plastic welded in place) at the tank bottom is dripping fast. Does not appear to be from threads on elbow screwed into outlet. Can I seal this from the outside with 5200 polyurethane?
P
Peggie Hall/Head Mistress
Uh-oh...
Nothing bonds permanently to polyethylene, so if the tank wall is cracked, the only option is replacement. But if it's only the weld that's failed, any shop that works with poly and has a spin welder should be able to repair it. Fortunately it's a water tank...'cuz I don't know of ANY shops that will work on a used waste holding tank. Look in the Yellow Pages for plastics mfrs...if you can't find one locally, I'll give the name of a company to ship it to...it won't cost you but about $6 plus UPS both ways, which isn't more than $10 each way for a tank that small.
