Waste tank (not sure how large it is) on 2005 Hunter 33 acquired 2 years ago (I think I am the 5th owner) seems to have a leak pooling on the top of the tank , running over the side into bilge. Survey at purchase rated it is good condition, though I always questioned that as tank was visibly bulged and there was residue from an older leak, signs of maintenance work. [See tank from Side; looks nearly same as before but of course wet now from use] These leaks seemed to be old however and nothing was noted until rather recently as temperatures started to exceed 80oF. Recent photography reveals hose (which i think is coming from the head) no longer firmly anchored to the tank [See tank from above, connection is not tight ... cannot remember if it looked that way before i think it did ...]. Tank has only been emptied 2 times since purchase. No one poops in the head, just urine, and only in last 6-9 mos or so. Issue discovered as temperatures started to rise and smell of old urine began wafting from tank compartment into rear stateroom through to salon. Cannot tell if vent on outside works, though probably it does is as a stream of dirty liquid drips out of it after head is used [see ExteriorVent] . I do not think it is blocked. Solenoid also does not work, has never worked since I have had it. Given the bulge and the loose hose (how much pressure could have caused that and how likely can a good seal be gotten from cleaning and tightening? Wondering whether this rates another repair or probably a complete overhaul, and if it can be done in the wetslip (Which I think it could be). Looking for recommendations on approach, source of parts .... How difficult is the replacement?
