ross bounds
I'm sure this question has been asked many times before, but here goes. The packing seal on my drive shaft before it goes through the hull has started to drip. Leaks a little more when the shaft is turning. I don't know the history of the boat but I would guess the seal is several years or older. Should I try to tighten it or could that make the problem worse? Also, is it possible to change the seal with the boat in the water or is it not worth the risk. Can packing be added to it or is it a one piece seal. Would appreciate a diagram of the connection if someone has one. Thanks in advance for any help or advice. R. Bounds
