E
Edmund Shanahan
I've just completed the delivery trip from Charleston, SC to Yorktown, VA for our 89 Hunter 40. It was a good learning experience on handling the new boat. My first concern on the list is water leakage around the sliding plexiglass companionway hatch. I knew there was a leak, which over the years has ruined the wood supporting the steps, the engine top cover, and the rear and side bulkhead supporting the engine access area. All has to be replaced. But before that, I need to stop the water. During many rain storms on the trip, I could not believe the amount of water that would lay on top of the hatch and roll off the edge right under the pleiglass to drip inside from the aluminum channel. With a little wind creating a heel, the water built up along one side even worse. Water even poured in from the forward edge of the hatch when the wind blew the rain from aft. Has anyone experienced this and solved it? Going through the website a month ago, I found a fix it solution for the aluminum hatchboard channel, which I was hoping would be my problem, but after this trip I know I have more than that to blame.
