Leaking Packing Gland
Mark
I have a packing gland that leaks what seems to be more than normal. Another boat owner told me that a few drops every few minute was normal. Mines drips more than that. I have adjusted it a few times and my fear is that I will break something or strip the plastic bolt. Is there some sort of a washer inside of the packing glad itself or grease that should be put on that will slow the dripping down. I am aware that some dripping is require for cooling and lubrication, here again this was by word of mouth. Is there a diagram or a book that has maintenance tips on packing glands?
Jeff D.
Washer
It sounds like you have the plastic stuffing box. On most of these Hunter put a large plastic/nylon washer between the lock nut and the packing material. It is a bear to get out. HINT (once you get the washer loosened, cut it at an angle so it can entirely removed from the shaft and put back on)If the flax is that compressed already, you may be able to put another piece between the locking nut and the washer until you get hauled and can do it right. Before that, you might keep taking a quarter turn on the lock nut until the water slows down. Good luck!
E
Ed Schenck
Confusing.
I probably should not comment having never seen one of the "plastic" stuffing boxes. But your use of the term "locknut" makes me wonder if you are adjusting the right thing. When people ask about stuffing boxes I usually point them to the Related Link, a picture. To me the locknut is what "locks the box", keeps the "hex spud" from loosening. It has nothing to do with the compression of the packing. We back off the locknut, tighten the body to compress the packing, and then lock it. Is the plastic box different? Note that even this picture is confusing. The hose looks smaller than the body. As we know the body fits inside the hose.
Jeff D.
JOY OF STUFFING BOX
The plasic/nylon stuffing box is different than your illustration. The piece of hose does connect to a barbed fitting but the other end is a female fitting instead of a male fitting. There is hex nut as an integral part of the unit. The "lock nut" is a male fitting with an integral hex nut which goes into the female fitting. THis is what compresses the flax along with the plastic washer. There are holes in the hex nuts through which a cotter pin is inserted to keep it from backing out.
