Bob
I have a 1980 27 Hunter. The boat was surveyed on the ground three weeks ago. The survey found no problems with the hull and I didn't notice anything either when I made a visual inspection. When the boat is operated under sail there is no problem. The bilge stays dry. When the boat is operated under power with all through hull fittings except cooling water closed, water seeps in from the three aft keel bolts at a rate of about 1 gallon every two hours. It starts with a small amount of flow and then increases in volume after about 10 minutes.I have three questions: One, has anyone else experienced this? Two, what is the recommended repair?Three, is there any problem with just living with this for the remainder of the season and attacking it over the winter? Thanks!
