Hi all
My 2000 Ben361 has a Westerbeke 30B3 with about 1200 hrs. All running great but have persistent leaking around the "radiator cap" on the heat exchanger. I've replaced the cap with Westerbeke's authorized part (14lb pressure cap) three times in past year, but to no avail. I've also carefully cleaned the mating surfaces and checked the seals on the cap - all look fine. I can see no cracks in the heat exchanger at or around the fill port.
Anyone else seen this issue - any recommendations on next steps to take?Thanks
Pinch
Pinch
