Leaking Compass
Feb 2, 2008
14
Hunter 380 Santa Barbara
This weekend when we got to the boat and after taking off the canvas I noticed the original Suunto compass on our Hunter 380 had leaked all the oil out. Since new in 1999 there has always been a dime sized air bubble in the dome. Never got much bigger or smaller with the weather so I left it alone instead of possibly causing a leak if I tried refilling it. Has anybody replaced there compass? Suunto is no longer making marine compasses so what compass did you choose? So far I think Ill go with a Ritchie Navigator FN-203 as its the closest size to original.
Nov 30, 2015
1,343
I'll probably not be much help, but I put a FN-201 on my 78 H30C. My oil drained out too, most likely from a real rough winter or two. The compass fit easily and I only had to redrill three holes in the pedestal. This is what the kit contains. The cover was a little extra $$.
Jul 29, 2004
411
Hunter 340 Lake Lanier, GA
Repaired a leaky Suunto once on our 340, but the second time I was advised the repair bill would be as much as a new Ritchie. It did require opening up the large hole and new mounting screw holes. Ritchie Helmsman 742
Jul 4, 2011
68
Cal 33 ft. MKII Clayton, N.Y. St. Lawrence Rvr
When my Ritchie compass leaked out over one winter, I contacted the company shipped them the compass, they filled and sealed it. It has lived happily ever after for the last 15+ years. If it happens again I will definitely send it back to them. You would not go wrong installing one.
Mar 13, 2011
175
Islander Freeport 41 Longmont
I was able to buy the parts, including a new dome and seals for my Richie compass and do the repair myself. Not sure what the factory charges but I did it for about $75 and got to learn all about how the compass was constructed as a part of the process. Not a hard job and not too technical. The hardest part is figuring out how to fill the compass with fluid once you have everything back together. I found a bit of surgical tubing and a squeeze bottle worked well.
Enjoy
Feb 2, 2008
14
Thanks everybody.. I ordered a Ritchie FN-203 and it should drop into the existing hole. We will see this weekend!!!
