I have found I have a leak from the starboard coaming box (cockpit cubby hole). Basically where the bottom of the box meets the boat is separating from the inside of the coaming slightly. This is allowing water to drip down and run along the wiring channel under the cockpit bench. I verified this is where the leak is coming from by taping kitchen plastic wrap over the box and waiting for it to rain. With the plastic wrap in place the leak is gone.
My hope is to repair this from above/outside the boat. I plan to clean and dry out the failing joint between boat and box. Then I think I have two options:
1. Slather 3M 4000 in the seam until full.
2. Slather thicken West Systems into the seam until full.
I'm unsure which would be the best option here as they both have what I think are advantages. Seems like 4000 would remain somewhat flexible if the boxes flex at all. I would think it might stick better to a less than perfectly clean surface. Epoxy would be more solid, but with no flexibility, will it separate again?
I drilled a few test holes (inside the quarter berth), I found two spots where there is some wetness in the wood core of the cockpit bench. I cut back the fiberglass and luckily found clean wood. Nothing is black or rotten looking. I plan to leave these areas open to dry out for a while before I fiberglass them back in. Oddly both of the spots I cut out had duck tape, which was holding the wires in place from the factory.
The only other thread addressing this issue I found is here:
https://forums.sailboatowners.com/index.php?threads/cockpit-pockets-separating.195940/
But unlike the photos in that post my boxes seem to be "enclosed" from below deck. When inside the quarter berth I can not see where the boxes attach to the boat (see second pic).
