I've got a 1985 S2 11 meter aft cockpit sloop. I've had occasional leaks at the chain plates. The deck was not originally sealed, and I removed the chainplates a few years ago, removed wet balsa, dried the area as best I could for a few days with a hair drier, and sealed the deck around the chain plates with West epoxy. Removing those 12" bolts from the upper shroud chainplates was quite a job, but I enlarged the holes slightly in the laminated plywood stringers a bit and greased the bolts with bees wax when I put them back. I used Sikaflex to seal the chain plates to the now sealed deck, but the hull must work enough when beating that the sikaflex doesn't remain attached to the now sealed deck. Water then runs down the shrouds past the deck and into the cabin below. I've recently sealed the area around the chain plates with automotive goop, and that works for a year or two, but it eventually pulls away too. Is there a better solution?
