Leaking chain plate
Ron D
Jun 16, 2004
24
Hunter 28 Ventura
1991 Hunter 28 my starboard chain plate is leaking water into to cabin, it doesn't look too difficult to repair. Secure mast with main and spinnaker halyard starboard side, mark turn buckle thread positions remove and remove chain plate by removing the four exterior screws and loosen the large nut in the cabin and it should screw out - right? Also what type of sealant should I use ? If I'm going about this wrong or leaving something out, please advise. Thanks Misty Seas Ventura Harbor, CA.
Dec 25, 2000
6,071
Hi Ron, looks to me like you're on the right track...
I've been very pleased with the performance of 3M4200 above the waterline and 5200 below. That is what I would use if it were my project. It might be worth a call to Hunter Marine Customer Service and request their input to your repair plans. They may provide additional technical tips. They always have for me. Terry
RJ9757
Jun 15, 2004
29
- - San Francisco
One suggestion
This is probably fairly obvious, and may have already been part of your plan, but I would also loosen the port shrouds, after marking the turnbuckles, and then tension the shrouds evenly and symmetrically when you re-tune the rig. Have fun- Rick
Ron D
Jun 16, 2004
24
Hunter 28 Ventura
RJ and Terry Cox - thanks
RJ and Terry Cox thank you for your suggestions - 3m4200 I'll look into that and RJ I was not going to loosen the port side but that does make sense to me - thank you again.
Dec 25, 2000
6,071
Hi Ron, just a follow-up note...
Our Home Depot stocks 3M4200, probably at a better price than WM. Terry
Ron D
Jun 16, 2004
24
Hunter 28 Ventura
Off to Home Depot I go !
Terry the 3M4200 is what Iam going to use - good suggestion.
