Here's what I've worked out through some trial, error, and research.
1. There will be water in the mast. There are too many holes in it (halyard exits, fittings, instruments, etc.) to seal it. You can try and seal things like instrument and antenna cables, but you will only diminish, not eliminate water entering the mast.
2. Once in the mast, some of the water will run down the wiring bundle to the base of the mast. If there is a drip loop in the wiring before it passes through the conduit into the cabin, the water will drip free and accumulate in the foot of the mast. If the drains are clear, this water will leak out harmlessly. If the drains are blocked, this water will eventually rise to a level where it spills into the conduit and into the cabin.
3. Once water flows through the conduit and into the compression post, it will continue to follow the wiring. If you have a drip loop inside the compression post before the wiring exits, the water will drip free and accumulate inside the bottom of the compression post. You most likely won't see it, but it will be there. It should ultimately find its way to the bilge through an internal drain path. If not, it will just collect.
4. If you do not have a drip loop in the wiring inside the compression post, the water will follow the wiring into the overhead liner, and start appearing all over the boat, dripping from lights, fixtures, and along the edges of the cabin overhead.
So to sum up, drip loops in mast base and compression post and clear mast foot drains means no water in cabin. No drip loops and/or clogged drains likely means water everywhere. I'm still looking for a reliable way to maintain a drip loop in mast wiring when stepping the mast. I think the only way to be totally done with the problem is to modify the wiring path to exit out the side of the mast above the foot, bring it through the cabintop via a separate deck fitting, and cap off the existing internal conduit. Several companies make stainless steel deck wiring caps for this purpose.
