Leaks and Iceboxes
H34s are famous for leakage in the icebox drain "system," resulting in wet floorboards, which ruins them and usually requires replacement.The PO of my 34 rigged the icebox drain to a manual plunger-type pump at the galley sink... rather than let gravity do its thing and drain the condensation water to the bilge (with the resulting stagnation, buildup, and potential odor and damage to the floorboards), we transfer the water from the icebox sump to the sink and overboard through the drain. It works fairly well, and the sole stays dry from icebox water.As part of the re-route of the icebox line, a circular Beckson access plate was installed at the base of the icebox, allowing inspection of the drain line and the fittings. I don't believe that is a factory standard installation.We do, however, get some water on the sole from rainwater leaking at forward starboard corner of the companionway sliding hatch. During a rainstorm, water accumulates in that corner (due to the H34 patented starboard list)and, at some level, cascades out as a stream. We place a wastebasket on the sole between the starboard side of the companionway ladder and the galley counter/sink when we leave the boat and always come back to find some water there (if it has rained a fair amount in the meantime).Often, when we have water in the wastebasket, we also find water splatter on the countertop, and some standing in the sink (through hull closed). The stream of water from the companionway hatch leak splashes on the countertop and into the sink when the boat is rocked by wind or waves....I would think a dodger would keep that source of water to a minimum. My bet is on a problem in your icebox drain line. Some questions:Does water accumulate there even if there is no rainfall since last inspection?Is there ice in the icebox or water in the sump when you leave the boat?Is the countertop and sink dry when you find twater on the sole?If the answer to these questions is "yes," I think you have a leak in the icebox drain, or a blockage in the bilge weepholes. For a fix, I fully endorse the re-rigging from the box outlet to a pumb to the sink. It really works well.One more thing to check... we had a problem once with the sharp edge/corner of the Origo stove cutting the bilge pump line to the through-hull when the boat was heeled, resulting in a slow leak of bilge water below the stove onto the sole in the galley. The fix was easy, we installed gate hook to limit the gimballing of the stove, and spliced a repair to the bilge line (with the hose claps, it is also somewhat "armored" in the affected area). The leak was very slight, but the water was stained and pungent... like Brylcream, "a little dab'll do ya."As for the stuffing box question.... I would say put the tranny in reverse. At 2 knots, it doesn't seem like much, but at 20 hours a day (assuming 4 hours of slack tide), thats 100 nm of freewheeling in the Monday through Friday typical "off" period for a pleasure boat. I'd be more interested in the wear on the cutless bearing over time, especially if the water is silty. After all, you can easily monitor the stuffing box and adjust as required. The cutless is a little more complicated to check and repair without a haul-out.-Hooper
