leak
Sometime it is difficult to find that pesky leak. Ok, here we go.First pour red food coloring or cool aid down into the water tank. If you see reddish water, then the tank is leaking.Check the gasket under the washer that is beneath the wing nut and the drain bail plug to see if coming in. If not, look beneath the compression post by removing the plates at the base of the compression post and observe while sailing and/or motoring. To find out if the water is coming from topsides, close off everything well except for applying plastic over the main hatch way with a leaf blower taped around the plastic forcing air into the boat. Take a brush using soapy water and brush everthing topsides to see any airbubbling out of the boat which will tell you where the leak is topsides
