We have a recently acquired 1999 Beneteau Oceanis 461, and we have a pesky leak in the forward bulkhead just aft of the anchor locker. Wondering if anyone else has seen this and/or has found a solution?
I have a 2000 Beneteau 461 with 3 water tanks . 2 under the floor boards in the main cabin . 1 under the V-berth in the forward cabin . Each one holds approximately 70+ gal. This winter I left them
Hi folks, This one may be owner specific to those with early 2000's Oceanis', it appears that the shower water is somehow getting into the bilge, whilst it's not the end of the world it's really getting on my wotsits. Does anyone have a similar issue, have you managed to remedy it? The annoying...
I have a 2006 Beneteau 423 and the forward fresh water tank has developed a number of leaks in the lid (top surface) of the tank in the last year or so. These are mainly pin-hole leaks, which I have been successful at patching, but I am concerned that there is an underlying root-cause behind...
My 2000 Beneteau 411 has several leaks that I have traced to the deck/hull seam under the teak toe rail. I can watch the water drip in along the screws that bind the deck to the hull. I have removed caulk and caulked the toe rail edges. Still leaks? Not a big deal but aggravating! Can’t seem...
