Summary of Sources
Wow, more 31 leaks. There are several archive conversations on the same boat/subject if you'd like to see some previous sources of the water and the solutions. Something I didn't see mentioned in this list of responses was the water fill and emergency tiller deck plates in the cockpit. Believe it or not, these can leak into the aft cabin as well. You stated that the leak travels down the carpet. Is that on the aft bulkhead or the port bulkhead, could be different source for each. Here's the summarized list of sources of water in the aft berth: (I've discovered 9 of these on my boat so far; still haven't fixed all of them I guess, I still get a bit of water now and then)1. Cockpit port light2. Any thru-deck screw on jib track3. Fixed Port Light- port side4. Port Port Light above Nav station5. Binnacle (compass, mounting screws, etc.)6. Spinnaker sheet/guy block thru-deck screws7. Winch/cleat thru-deck screws8. Rope Clutch thru-deck screws9. Halyard winch thru-deck screws10. Water fill deck plate 11. Water fill hose has hole12. Emergency tiller access deck plate leaking13. Water overflow/air vent hose has hole14. Stanchions15. Stern pulpit16. Scupper and/or hose leaks17. Stern locker lid(s) allow rain in stern lockerWorst Case so far:18. If no water is seen dripping but under sides of berth cushions are wet, numbers 11 and/or 13 above may apply, but you may also have a water tank/compartment sealing problem. On my 31, there is no water tank, instead, there is a water compartment which has a lid screwed down onto the top of the water compartment and probably 40 lbs of sealant. If you overfill the tank/compartment, and the seal has even the slightest leak, the gravity pressure from the water in the fill hose will force the water in the compartment out of the top of the "tank" and into your beloved berth cushions causing them to stain, mildew, and finally rot. This is most unpleasant and requires almost a whole weekend to repair. At least you get to see the inside of the water "tank". I hope you never experience this.Good Luck on your repair. If you find a source of water not listed above, please post it here in the forum. ThanksJay
