Reply to Kevin about reefing lines
You're right, it is a poor design for the reefing lines. I changed mine 2 years ago and it works great now, I look for excuses just to reef. First of all I had a second reef added to my sail, now I can go out in a lot wind. Next I added a block on each side of the boom, 1 for each reefing line. These I located straight down from where the reefing line touches the boom. Next I replaced the lines with much longer ones, I don't remember how long but you can measure when every thing is done. These ran through the boom the same as the original one,also got rid or the jiffy reefing lines inside the boom. I ran the lines out of the boom down to 2 blocks added near the base of the mast, then through a deck organizer on the port side, on the flat surface like the one that comeswiththe boat on the starboard side. There is an aluminum plate under the glass there so it is easy to drill and tap for the mounting bolts. The lines are then ran through a rope clutch mountedon the flat spot ,just like on the starboard side. Again there is an aluminum plate under there ot mount it.
