DIY
Gerald, Mount a couple of Harken cheek blocks on the mast just below the second set of spreaders. Mount two small nylon cleats on the mast at the goose neck. Four small eyes spaced under the boom. Make up the lazy jack lines by trial and error to catch the sail. Anchor the bitter end at the nylon cleats with about 24" of elastic cord. The hole mess stores along the boom over the cleats and up to the cheek blocks. When lowering the main, unclip the line from the cleats pull up the jacks by hauling on the line that leads up through the cheek blocks and tie off to the cleats. Drop the main, tie off, then restore the jacks to the stored position along the boom and up the mast. Use your regular sail cover. It sounds messy but it works like a charm and will cost less than $50. I have had a set on my 88 30 for years. One little extra, if you put a plastic grommet in the extra hole at the base of the first spreaders then it can serve as a fairlead for the bitter end of the hauling line. It takes a little playing to get the lengths right but is well worth the effort. Good Saturday project.
