Lazy jacks
Aug 17, 2013
1,340
Pearson P30 202 Ottawa
Hey everyone, I« m thinking about making lazy jacks for my Pearson 30.
I know I need either turning blocks (or whatever they are called) to put on the mast or fixed points if I don‘t want them adjustable.
I was wondering if I should put blocks or lead rings for the legs?
would you recommend 3 or 4 legs?
what size lines do you recommend?
I want to slowly get ready for another project, a sail pack, I made one on my old boat and just loved it.
Turning blocks. You do want to be able to adjust the lazy jacks, especially to pull them forward when sailing.
Low friction rings will work as well as the tried and true SS rings.
4 legs is better, less room for the sail to fall out.
5/16" lines work well, ¼" would also work.
Look at the design for the sail pack you will build. Install lazy jacks that are compatible.
Likes: Mak41
Jan 7, 2011
5,999
Oday 322 East Chicago, IN
I put small blocked mounted to the mast about 4 feet or so above the spreaders. The first leg goes up to the mast blocks, and down to the next leg. The bitter end cleats off on a plastic cleat on the boom. On my Mack Pack, the legs all have small plastic blocks. Makes tightening, loosing or pull them down and forward to the mast all that much easier.
I am not sure size the lines are, but on mine the first (and longest) are thicker than the next leg. I think 2nd and 3rd legs are the same diameter.
Not sure that there is much info of value, but here is a video from the day my friend and Tom and I installed our Mack Pack…
Projects are so fun!
Greg
Likes: Mak41
Feb 20, 2011
8,062
Hm, I pull mine forward after I'm back at the dock.
Set them during my tacks so they're ready to contain the eventual drop.
It's not like I'm racing or anything.
Previous owners did an excellent job designing them, but I doubt a sail pack could be accommodated with the design.
May 7, 2012
1,623
Hunter e33 Maple Bay, BC
@fred1diver have you had a read of this article. It may answer a few of your questions.
Lazy Jacks Sail Tamers
Aug 17, 2013
1,340
Hello Below, yes I did read it, great article, I guess I am just looking for more info, I did source out what I will be using as blocks for the legs, but still looking at all the options for the mast or spreader blocks, also wondering what the smallest line I can get away with is.
Aug 17, 2013
1,340
Ok, so I mounted my cheek blocks on my mast at around 70% of the mast, getting ready to get the lines ready, I opted on Ronstan Shocks Xl instead of blocks, now my question is should I try and splice the lines or just sew them and whip them? Or would a knot just suffice?, I’m Leary of a knot as it can come undone and I think it would chafe too much
Jan 7, 2011
5,999
Those are pretty cool, and should work ok.
if you can splice, that is the best looking way to do it. But if not, one of your alternatives would work. If you knot it, and are worried about it untying, you could put a few stitches in it to ensure it doesn’t untie.
On my jacks, from Mack Sail, the little blocks are spiced in the line the smaller jacks just have a low friction ring, also spliced into the line.
Greg
If you read PS's conclusion you will find the sewn splice holds up over time and it is a useful tool for certain conditions, like having tight space on lines of light force.
I felt this defined the system of lazy-jacks on my boat. I wanted a tight eye splice on the line. This made the typical eye splice technique difficult. My sewn eye splices take up little extra line/space and have held over the past 2 seasons. They do require regular inspection. I will sew splice them again should they need repair.
Mar 26, 2011
4,010
Corsair F-24 MK I Deale, MD
I'm surprised no one has brought up Dyneema, if low friction and minimum size are important. Polyester single braid (what Sailrite recomends) is also nice --easy to splice.
Aug 17, 2013
1,340
Yes I agree that dyneema is a great rope to work with, but I already bought the double braid, normally I would have spliced it, but I find the smaller rope is hard to splice
Mar 26, 2011
4,010
Yup, small double braid is a buger to splice. Use a sailmaker's sewn eye.
