I have two blocks below my lower of two spreaders on the mast, one block each side . Nothing is attached and I thought they were part of an old Lazy Jack system. They seem low however as most say to go above the spreaders. If I get a system that I can retract and tie against the mast when raising, is there a need to go that high up? Won't the sail fall in line and flake even if the line isn't going as high as above the first spreaders?
