Someone dropped or stomped on the lazarette. The rubber bumper had worn away, and the offending screw made a radial crack a bit bigger than a quarter on the seat (see the picture).
My plan is to remove the broken pieces with a dremel, fiberglass the hole from the underside. Fill the void with Marine Tek and gelcoat.
Any better ideas or wisdom before I hack at my crack?
