Nice extension! Great pictures!
If your three bolt H type clamp for the extension is bolted to the center of your square tongue tubing, you might be able to rotate it backwards out of the clamping position and let your extension move a bit, relative to the tongue, if you ever got wedged into a tight spot. It looks like the square tubing of the extension may be able to slide underneath your tongue and fit in the bottom part of the H, to stow that end of it?
Those are very excellent and useful pictures, thank you. As I posted below to Chief, I wouldn't have guessed that the ball and trailer tongue would be fixed on the boat end of the extension, but I guess that makes backing up a lot easier and double jack-knifing a lot less likely. Since Chief's extension is pretty short (Sorry about that Chief!), the torque on his receiver would be correspondingly less and his angle between the extension and the trailer tongue isn't fixed. My head was getting all squirrley with the idea of an extension being unfixed at both ends and trying to back up into C and Z curves!Chief, that's good to know. If my trailer extension ever rusts out, maybe I'll just try a long receiver extension.
Here are some pics of the extension I designed and my friend built for me. It doesn't slide, and removes completely. He's going to make a bracket to hold it onto the trailer so I don't have to strap it on with nylon cam buckle straps.
Brian
