Latest brainstorm
3,562
Endeavour 32 Portland, Maine
Having experienced the incredible heat gradient in the cabin while testing my new cabin heater, I decided that a prototyping session in the madman's workshop was in order. The 12 square foot radiating surface of my bulkhead water tank makes the upper part of the cabin especially toasty.
I haven't yet been able to identify a space that would be practical and desirable to install a permanent air circulating duct so I'm going to try a portable arrangement. This is a computer fan mounted in a cannibalized heat diverter for a dryer.
The aluminum dryer hose will be hung from a hook in the overhead near the stove and the fan plugged into a jack attached to the power supply to the cabin heater fan. It will suck hot air down from about 6” under the cabin top and spread it around the cabin floor.
There are two or three places I can hang this thing depending on circumstances. There is also the potential to bend it around, say to push some of that heat into the forward cabin.
The aluminum hose compacts down to about 6” long for convenient storage. If it works well, maybe I’ll make up something a bit more elegant looking for the bottom housing. It may also help me figure out the best location for a built in duct if I can find a place to run it.
RAD
Jun 3, 2004
2,330
Catalina 30 Bay Shore, N.Y.
Roger,
I've been heating with an air tight stove for 30 years and I found that those little computer fans just mounted up high on a door jamb will circulate the air and spread it around so you might be able to do the same in addition to the duct if you can hide it
Nov 22, 2008
3,562
If the duct turns out to be a pain, the same fan might just end up mounted somewhere in the cabin. I'm thinking though that having some of that very hot air that collects in the top of the cabin coming out right at the floor would make a very nice place to put cold, wet feet as well as providing mixing.
Dec 2, 2003
1,637
Hunter 376 Warsash, England --
Great thinking.
This problem arises in houses too and I once saw a very slow revving fan in a 10" duct from floor to ceiling to recirculate the hotter air at ceiling level. The slow fan was silent, used negligible power and did not cause draughts.
Worked a treat
DannyS
May 27, 2004
933
Beneteau 393 Bayfield, Wi
Gotta love how one project creates another. Great work on the first, I'll be interested to see the elegant final product on the second.
Sailm8
Feb 21, 2008
1,751
Hunter 29.5 Punta Gorda
A good 32inch ceiling fan would do the trick. Just keep low
