K
kenny
Surveyor discovered- through a percussion test- 3 different 4" x 4" areas of delamination on the deck of the 2000 cat 320 i am about to purchase. The areas showed no water seepage, nor are they located near any structural supports.. ie cleats etc... Surveyor suggested delamination was probably a fault in the manufacture. As I have read about delamination, or core separation- I realize it can be a serious and expensive thing to repair. The cheaper method was an epoxy injection- via holes drilled, the other involved much time and labor. How concerned should I be? The boat was pristine otherwise. The areas in question showed no signs of stress or cracking. Is this a deal breaker, or is this a fairly common phenomenon in used boats that is easily rectified? What should i expect in terms of repair costs? any help would be appreciated...thx
