Last season's 2 cycle gas mixture
Ron
if in doubt.....
If all the advice balances out at 50% for and 50% against running it, and you are still uncertain about what to do, some service stations will dispose of it for you.
Aug 2, 2005
374
pearson ariel grand rapids
old 2cycle
I normally fill my bike for the last time of the season with two cycle mix, run it for a while, then pull it in the garage and shut the gas off and let it burn out the fuel in the bowls, shut it down and hook up a maintenance charger on the battery, come spring turn on the gas, let the bowls fill and go riding, done that ever since I moved into a 'seasonal' state, and have never had any issues from it, still riding the same old 1974 honda cb750 I started out with 20 years ago. the only parts replaced have been clutches, plugs/points, tires, brakes, and light bulbs ken
Dan
Stabilizer in the oil
I reciently found out that some air cooled 2 stroke oil ( the bottle I just bought) has the stabilizer already mixed in. I wonder if the watercooled oil has the same thing.
