Headsail
Glenn,I just purchased an '87 26.5. It also only has a 110 Genoa. I've been told by an experienced sailor (and very good friend of mine) who has an '88 28.5 that I should absolutely upgrade to AT LEAST a 135, but that a 150 or 155 would be better. Either one of these will fit, and will significantly increase performance. Note that the current jib is set up for roller furling. Using these larger sizes allows you to change your jib size at will, so the bigger the better.BTW, I am currently looking for a used jib online (don't want to spend 1000 bucks after buying the boat just yet).Hope this is of some help.Jim.
