Second Every Word
Hi, David. We have a 340; some hull and sail plan as the 336. We would second every word that George says. Putting a big genoa on would really go against the way the entire rig is designed and balanced.The only reason to even think about a big genoa on a 336 is if you sail constantly in very light air. If anything, the 336/340 sail plan is already over-sailed. There is a LOT of sail area up there, assuming of course that you have the standard roached main. That means, if anything, reefing early; we will find ourselves putting in the first reef at about 15 knots, sometime even less. Last year overall we probably sailed with at least one reef as much as we sailed with full sail. We make the reefing decision based on heel; the 336/340 hull much prefers to be sailed relatively flat; 15-25 degress heel, no more.Again, unless you sail essentially all the time in very light air, you already have more than enough sail up there. Carl and Jules/v 'Syzygy' (In the water two days ago!!!!!)
