Larger Crank Case Pulley
Oct 7, 2008
380
Oday Oday 35 Chesapeake Bay
I needed to replace my crankcase pulley on my M25 21 horse power Universal Diesel motor. When the tension from the belt was off, there was close to 1/4 inch of slop in both directions. I suspect that the larger alternator (120 amp) was creating more tension over the years then it was originally designed for and the key became worn. I ordered a used pulley from TOAD Marine which solved the slop problem but I realized that the pulley was 1" diameter larger than the original pulley. Will this larger diameter effect other parts of the engine? According to a local diesel mechanic it will not. Any other thoughts on this?
Dec 3, 2013
169
HUNTER 29.5 PORT CHARLOTTE FL
FWIW
The larger drive (crankcase) pulley will, at a given rpm, drive the smaller driven (alternator) pulley at a faster rpm.
Call Joe Joyce at Universal/Westerbeke --- Westerbeke's Service Manager (508-823-7677 X234), and ask him.
