Laptop chartplotter/gps help
628
Legnos, Starwind, Regal Mystic 30 cutter, 22 trailer sailor, bow rider NEW PORT RICHEY, FL
Hi everyone, happy breezy New Year. I recieved a Toshiba used laptop for Christmas, downloaded seaclearII, and a bundle of NOAA charts, and unzipped them. How do I get the charts into Seaclear so I ca use them? Also, I have a handheald gps and want to use it for boat position...what is the cord called that hooks the gps to the laptop? I have a sortof like coax output on the gps, and i suppose the usual USB port inputs on the laptop.
Thanks for the replies. THe "free boat" is slowly comming along-SV Free Willy. Patrick
Sumner
Jan 31, 2009
5,254
I downloaded Seaclear and I'm having the same problem downloading the NOAA charts into it, so I'll be interested in the replies you get.
I did also download OpenCPN............
http://www.bigdumboat.com/cpnindex.html
................... and have been able to use it will little problems and so far I like it and I think it will also do what you want. You can't load the charts into the GPS with them, but you can download your route waypoints and track your location real time on the computer if you want. You might want to also look at it.
On the wiring, I haven't tried that, but I'm pretty sure there are two wires that are the important ones. One for data out and the other data in. I'm also pretty sure you won't be able to hook up to a USB port directly, at least I can't with my map76 GPS. You are going to have to use a serial to USB converter.
http://www.totalnavigation.com/Gilsson/Gilsson Cable Pages/Gilsson_R12C_Adapter.html
I got the above that will power the GPS and has the connector to plug into the GPS for the data that goes to the serial plug on the other end. Here is a cheaper place to buy it from and where I got mine......
http://www.cascadegps.com/store/gilsson-r12c-pc-interface-cable-w-cigarette-lighter-adapter.html
The DP 9 pin plug will have to go into a serial to USB adapter that will then plug into your USB port. I just got this stuff, so haven't tried it all together at this point, so can't help you there.
Hope this helps a little,
Sum
Our Trips to Lake Powell, UT - Kootenay Lake, Canada - Priest Lake, ID
Our Mac Pages
Mac Links
Tim R.
May 27, 2004
3,626
I am not sure about the charts but Seaclear should have a tutorial on how to import charts. See the link below.
http://www.sping.com/seaclear/mc_ii_man_en.zip
As for the GPS, it sound like the round port you found is for a remote antenna. What model GPS is it? Some older models do not have a serial interface.
Jul 24, 2006
628
I think it is a globlemap 76 or 100-I think
thanks for all the links and advice. I will try them all when I get home. Can't do to much surfing in th ICU, lol. The handheld gps' port is the same as my internal antenae Garmin 420 base mounted gps. I don't see pins or recepticles for them. Just a plug with an id hub kind of thing. I thought maybe an optic port???? Me so dumb.
Nov 26, 2006
381
Hunter 31 1987 Fly Creek Marina Fairhope,AL.
laptop connections
Q- How do I get the charts into Seaclear so I ca use them?
The charts dont go on the GPS , they go on laptop.
Q- Also, I have a handheald gps and want to use it for boat position...what is the cord called that hooks the gps to the laptop?
A- Depends on the laptop, If it hs a DB-9 ( pin serial input then you only need a connector from Radios Shack " less than 10 bucks "
Q- I have a sortof like coax output on the gps, and i suppose the usual USB port inputs on the laptop.
A - you also need a serial to usb adapter available from Best Buy, Radio Shack , even Office depot. Plugs into USB port and has a DB-9 connector
You then have to configure your software" presuming sea clear" to look at the com port that you set up on the adaptor.
I use Capn Voyager and Coastal explorer. Prefer Capn voyager over anything ive seen so far in being a professional tug captain since 1993
Good Luck and Fair winds;
Jul 24, 2006
628
thanks Chuck and everyone, I am getting it now. I prefer to go with free software and inexspensive cables. I think my hh gps will work, but when extra money is available then certainly a puck or usb? gps is the way to go and keep the hhgps for backup.
Sep 2, 2009
339
Hunter Vision-32 New Hamburg, NY
SeaClear -- NOAA RNC Charts
unzip your charts to the SeaClear/Charts directory ... then open the MapCal II program that comes with SeaClear
in MapCal II from the Tools dropdown, select "AutoLoad list" and then "Scan for new Charts". MapCal with then make the charts available to SeaClear. Open SeaClear and go to File==> Chart ==> list all ..... you should have your list ... select one!
Let me know if you need more details ... don't have much time right now to do a long post
Ron
Jul 24, 2006
628
ok, went home and checked the gps. Lawrance globlemap 100. it has two ports...the one mentioned previously with tiny hole in center like coax and a 6 pin jack. The laptop has what looks like 3 USB ports. I will now try to get the NOAA charts over to the seaclear program. thanks all. Patrick Ron, since i alreadt unzipped the charts I am going to try and copy then to the mapcal folder under seaclear/charts dir. Will post back
druid
Apr 22, 2009
837
Ontario 32 Pender Harbour
Most older GPS's expect a serial port (to be pedantic: NMEA 183 uses "balanced" signals similar to RS422, but RS232 works just fine). Unfortunately everyone says you don't need a serial port any more, so laptops don't have them any more. There are Serial-to-USB adapters, but my experience is less than perfect on them. But without getting a USB-capable GPS, I think they're your only option.
So you will need to get a USB-Serial adapter, and the custom serial cable for your GPS. EBay is an EXCELLENT source for both.
Oh, and for displaying NOAA (BSB3?) charts, try OziExplorer.
druid
Jul 24, 2006
628
ok Druid, you lost me atPEDANTIC. is that like frantic? I get that i need to use a serial to usb adapter. I think I will take the gps to radio shack and get their opinion? Hey Ron, unsuccessful at unzipping to c;\Program Files\SeaClear\CHARTS, the unzip copied it there but when i went to autoload list in mapcal it could'nt find it. Your direction was clear? I am just not too put'r literate
Sumner
Jan 31, 2009
5,254
I found out today you can set the directory/folder where it is to look for the files, but it has to be the folder not the parent folder above it. Use the "too" and then "set directiory". It has to be the folder with the *.KAP file for the area and it has to be the RNC files not the ENC files. At least I can't get it to see ENC files. Since I did the entire Florida area I had to set it where it looked to all of the different folders that NOAA setup, but it didn't take that long to load all of those paths.
I wish I would of come back and read Ron's advice it would of saved me at least an hour :cry:.
Sum
Sumner
Jan 31, 2009
5,254
Did you look at the tutorial from boatmaine? Chuck
I did, and thanks, but for some reason a couple minutes in it hangs and I can't get it to go any further. I tried it a couple times with the re-fresh and it hung at the same spot always. Maybe it is just a bad day for my computer. I'll try again tomorrow.
c ya,
Sum
Mar 12, 2008
557
Jeanneau 49 DS San Pedro, CA
Have you used this GPS dongle down below and gotten a fix?
I use the dongle below all the time. It uses Assisted GPS (AGPS) and with an open sky, it will lock on in about 15 seconds provided you haven't moved more than 500 miles from the last fix. Down below, it may take a little longer, 30-40 seconds, but it takes my laptop longer to load. Considering no antenna, works great! I like the fact that it charges off the laptop, so no batteries to deal with.
Jul 24, 2006
628
thanks everyone! With all your help i was able to get my charts loaded and played around with them in seaclear. Now all i need to do is get the cable to hook my gps to put'r and i'm ready to take off. I was thinking New Port Richey, FL to Tortugas, to key west and on to Andros isl. Anyone been to Andros? Thanks again for the priceless(free) info. Patrick
Oct 25, 2005
735
Catalina 30 Banderas Bay, Mexico
After wasting time and money on Serial to USB adapters from various sources that didn't work with NMEA 183 ...
SeaLevel makes one that works. So far 100% Not free, but if it makes the instrument system work is is worth it.
Link
