Lancer 30 with saildrive
srg610
Jun 17, 2009
3
BlueWater Bowrider Trailered
Hello! I just joined the site today, and had a question for the owners of boats with the Yanmar Saildrive. I saw in one post that Bob had replied to watch out for these units, as parts are hard to come by, and also had an issue with the hull seal failing, and sinking the boat. For those of you that have this system, I would like to know if you like it, hate it, and why. Is there any difference in manueverability than with a standard setup?
Thanks,
Scott G.
Oregon City, OR
Jun 12, 2009
6
2 30mk-v My front yard!
Scott,
I've recently purchased a 30ft lancer with the sail drive. Never sailed it so I can't tell you about maneuverability issues but from what i'm hearing yanmar has recently filed for bankruptcy. I've been told by a rep that he should be able to get ahold of some of those critical parts but i've yet to actually order them. I planned on dropping the saildrive and replacing the hull seal so maybe i can get you some more info soon. I'll likely try to order the stuff in the next week or so if I can.
BobM
Jun 10, 2004
3,269
S2 9.2A Winthrop, MA
Yanmar
Scott,
I have a Yanmar, so was interested in this. Scott, what is the source of your information. I can't find anything regarding this on either the US or Japan Yanmar sites or google.
srg610
Jun 17, 2009
3
Hi Bob,
Got busy for a few days.
I was'nt sure if you responding to me, or to 1sttime...
I thought I saw a post where you recommended avoiding these units, but on searching back, I cannot find the one I remember. I apologize if I put words to something you did not say...
In your experience, are parts readily available for the saildrive? Is there a major issue with the hull sealing joint? I did see some other posts today that comment on how much quieter the saildrives are, and that they back a good deal straighter than conventional setups. I would like your opinion on these subjects as well.
Thanks so much,
Scott G.
Oregon City, OR
BobM
Jun 10, 2004
3,269
For what its worth...
Hi Bob,
Thanks so much,
Scott G.
Oregon City, OR
All I know is from the research I did when I bought my last boat. As I recall, mechanical parts for the OMC are available, but folks were having difficulty finding the hull seal. Fortunately it isn't a part that fails often, but if it does I don't know if you can get one. This is likely out of date and you should do your own research.
Regarding sail drives in general. I wouldn't hesitate to buy a newer boat that had a Yanmar unit, but would think twice on a Volvo unit. The saildrive eliminates alignment issues. Diesel saildrives are common in Europe. In general, gas is less desireable than diesel irrespective of the final drive configuration. Diesel isn't as flammable and range is increased. I motored about 150 miles on 20 gallons of diesel last year. I wouldn't think that a saildrive would be quieter, unless it is because the exhaust is under water. I suspect that there would be much less vibration. Less noise and vibration are big pluses when you are motoring on passage. They cause some measurable fatigue.
I thought I found a great deal on a boat, but eventually my on line research showed me that it was likely a great deal due to the fact that Volvo doesn't support the engine anymore. Given the fact that my 1981 S2 has its original Yanmar 2QM15, which is 28 years old but still runs like a champ, I don't want a Volvo if they stop supplying parts after 20-25 years. Plus most of Europe takes August off. My season is only 4-5 months long. I don't want to lose half a season because they are on vacation.
The Volvo isn't a straight drop in, from what I have read. However, this might be http://www.saildrive.us/ and appears to be about $6-7000. From that perspective, any inboard repowering is likely to cost you that kind of money. I think that you just need to consider the fact that parts availability could impact you in making your purchasing decision. I would certainly expect to pay less for a boat with an OMC saildrive than an inboard diesel. I also would NOT buy a boat with an OMC saildrive without hauling it to inspect it for corrosion and checking the lower unit fluid for water (I think the fluid tends to get changed infrequently because the boat must be hauled to change it).
