No problema!
That's why I'm here!On to your question, there are too many things to list! Here's a sampling (mainly of 87+ features)- you should check out the difference first hand. It may not seem like a huge difference right off the bat but if you're looking for these things, you'll notice them. Here goes:*Anchor locker: one large door, wider & deeper, is molded for a windlass*Aluminum framed, smoked plex forward hatch*Four Lewmar Ocean Series opening ports on sides of the house*Two large, non-opening, smoked plex portlights (Euro-style) installed flush in sides of house - no aluminum frame*Liner pan for interior was changed. Less wood furniture, more plastic but far more storage, thus more liveability.*Aft bunk turned into a true double (HUGE! - except on headroom)*Later models have the walk thru transom & a non-opening portlight in side of hull*Roller furling was standard*Tall rig available w/or w/o bowsprit*First year wing keel was an optionI could on & on!Hope this helps.LaDonna
