Kohler generator
Brian
Anybody else have the 1997 Kohler 9EOZ generator powered by a yanmar 3TNE78 engine. My 1998 Passage 42 came with this setup and I am trying to replace the impeller on the generator raw water intake. So far I have had no luck locating a replacement impeller so I thought I would ask everybody here. If you have this setup and have found a source for impellers please let me know. Thanks for your help, Brian
Dec 25, 2000
5,950
Brian, I would try your local Yanmar...
service center. Hunter used Onan (Cummins) on our 1991 P42. I've been told by the local Onan service center that ours is a Kubota engine. Terry
Sep 14, 2004
198
Hunter 42 Deltaville VA
It has to be ordered
We have the same setup and the impeller has to be ordered by our service dealer every year. No big deal, just requires a little advance planning.
Brian
Thanks Bradley
I actually did go to them and they couldn't help. They also didn't take the time to try looking it up in any manuals....problem is that it's a sherwood impeller and they only try to match through sherwood catalogs. I think the PO must have replaced with sherwood and now they don't make this size impeller any more. Any chance you know the part # of the impeller so I can help the local guys? Thanks, Brian
Sep 14, 2004
198
Yes, but . . .
The part number is on the boat in the logbook. I will try to remember to write it down this weekend.
Jim
Brad - Help please
Brad, We have spoken before on the Bay and in Mill Creek, but I cannot find your e-amil .. so am using this thread. I am looking to have a Bimini made for my 42 and was looking at the example you posted a couple of years ago. Problem is that the resolution of your picture is not good enough to see how it is attached. Would it be OK with you if I went over to Deltavile and took some pictures. If OK.. where is she berthed - Marina/slip?? Thanks Brad. Regards Jim
Jim
Here is what I used
I used Kohler Part Number 22986 I had a heck of time finding an outlet to get one. I used one in Warsaw Va.. but they went out of business. The other number I had was Chesapeake Cove Marine in Deltaville 804-776-7572. In any case, suggest you order a parts/service manual at the same time. Also, when you take the old impeller out, do NOT lose the "key" (a small half moon piece of metal) which holds the impeller in place. These are very hard to find.. Good Luck
JIM
PS
I tried the 804 number I gave you last night.. and it is no longer valid.. it is no longer working.. probably out of business. As an alternate -- would suggest that you contact Hunter marine direct and their parts dept might help or Norton Yachts in Deltaville, VA
Brian
Thank you Jim!!!!
Now that's going beyond the call of duty....I am still trying to get help from the local Yanmar people here in So. Cal but no luck. Called them tuesday and still no reply. They all have a problem with the engine model #. Someday I'll get it squared away. Brian
Sep 14, 2004
198
Better number
Chesapeake Cove Marina. Broad Creek. (804-776-6855) Also, try Norton's at Norton's Yacht Sales. Broad Creek. (804-776-9211) Norton's is the Hunter dealer and they order this part for us every year.
