Knots Knowledge
Ducati
Nov 19, 2008
380
Boatless Boatless Annapolis
I now have two books about knots. (Gifts)
Time is short and brushing up on the 25-50 knots will "not" happen.
I would like to hear from others about your top 5 - 10 knots that are a "must have" as far as knots go.
Thanks
Oct 18, 2007
707
Macgregor 26S Lucama, NC
cleat hitch, square or reef knot, bowline, clove hitch, tautline (rolling?) hitch, overhand knot, 2 half-hitches, sheetbend -Paul
DannyS
May 27, 2004
933
Beneteau 393 Bayfield, Wi
Bowline, cleat hitch, figure 8, truckers hitch, prussic knot.
higgs
Aug 24, 2005
3,738
Nassau 34 Olcott, NY
Double half hitches, bowline, cleat hitch, square knot, clove hitch.
I find many good boaters who do not tie the cleat hitch properly.
Oct 22, 2008
3,502
- Telstar 28 Buzzards Bay
cleat hitch for docking
Round turn and two half-hitches for tying up to posts, attaching fender lines, etc.
Bowlines for attaching sheets to sail clews
Buntline hitch for attaching halyards to sail head shackles
Stopper knot or figure eight knot for ends of lines to prevent them from running through line clutches
Rolling hitch is very useful for taking the load off a fouled sheet on a winch so you can unsnarl it.
Jun 5, 2004
249
Hunter 36 Newburyport, MA
Cleat Hitch - to not lose the boat when away. (Seems unknown to powerboaters)
Bowline - to not lose jib (or MOB, who should know how to tie it blind around self)
Buntline Hitch - to not lose halyard.
Round Turn w/2 Half Hitches - to not lose fenders when away (or boat at pilings)
Larks Head/Cow Hitch - to quickly attach/adjust fenders to lifelines when docking
Fisherman's Bend - for snubber line shackles to anchor chain snubber plate
Rolling Hitch - to take strain off sheet in jammed line clutch
Trucker's Hitch - to do secure tie-downs.
Clove Hitch - because "you're supposed to know it" (to use if you're very trusting).
Fair winds,
Al - s/v Persephone
Ross
Jun 15, 2004
14,693
That about covers it. I always backup a clove hitch with a half hitch on the standing part.
2,288
C30 Event Horizon Port Aransas
bowline-if it needs to be untied soon
buntline-if I am not untieing it soon
cow hitch-for fenders, I used to add a half hitch but don't think it's necessary anymore-probably end up buying some fenders someday, but fenders are only used while I am docking or hanging out on the boat
square knot-for tying sail ties
fisherman's knot- for the Redfish at Port aransas
thief's knot so I can tell if someone has tampered with the grog, isn't that right Ross?
Oct 22, 2008
3,502
I'd point out that a buntline hitch is rather permanent once it has been used for any decent period of time under load...and effectively can only be untied using a KNIFE.
One last knot I'd recommend, just because it is a very useful knot and almost unheard of is the Zeppelin Bend. It is a very good knot for joining lines, even of different diameters and can easily be untied, even after being heavily loaded.
Ducati
Nov 19, 2008
380
Thanks everyone for all your assistance.
Little did I know that all these years I was tying many of these knots correctly without knowing their appropriate names.
Cheers
cwkemp
Feb 17, 2010
73
Catalina 22 Lakes George, Sacandaga, Saratoga, Champlain
One last knot I'd recommend, just because it is a very useful knot and almost unheard of is the Zeppelin Bend. It is a very good knot for joining lines, even of different diameters and can easily be untied, even after being heavily loaded.[/quote]
I second the thought on the Zeppelin bend. One I use is a Hunter's bend (named after a man not the sportsman), similar to the zeppelin but a little quicker to tie and seems to work well joining synthetic lines even of slightly different diameters and construction.
rfrye1
Jun 15, 2004
589
Hunter H376 San Diego
It is always amazing to me how many folks dont know the "proper" cleat hitch. I understand struggling with other knots because we dont tie them every day.
Sep 30, 2008
10
Oday 22 on trailer at home in Jewett City CT (15 miles from New London)
Wow, I know over 30, but top ones are:
bowline
bowline on a bight
miller's knot
diamond eye splice
carrick bend (to join two pieces of line, better than sheet bend)
sheepshank
clove hitch (learn to throw one)
manrope knot (on end of a line)
taunt line hitch or timber hitch
whipping the end of a line (hate burned or taped lines)
I guess those are the ones I use the most. Oh yeah, the "tugboat bowline".
Ross
Jun 15, 2004
14,693
bowline
bowline on a bight
miller's knot
diamond eye splice
sheepshank
Miller's knot-Sliipped constrictor?
Manrope knot- which one crown and wall or Mathew walker?
Taut line hitch=rolling hitch?
Timber hitch=Not rolling hitch
Sewn whipping?
PBJ
Nov 16, 2005
7
Hunter 31_83-87 Horseshoe Cove, CA
We used the following 6 basic knots teaching students in the ASA:
Bowline, Fgure Eight, Cleat Hitch, Reef / Square Knot, Clove Hitch, Round Turn and Two Half Hitches. Then we'll added the Sheet Bend, Rolling Hitch, and finally the Trucker's Hitch for the next two classes. I use the Bowline, Reef, and Trucker's knots almost daily away from the boat. I'd say these 9 would get you through most any sailing situation. If I were to name 2 knots to know in your sleep, it would be the Cleat Hitch and Bowline. The Cleat Hitch will be what you need to do to secure the boat when you're tired and cold and the Bowline will be the knot to save your life in an emergency such as someone falling overboard or needing a tow away from terra firma.
