I did not have one on the last two boats and don't have one now. Don't race and never really gave much thought to know how fast I was going as long as I was going. However, I am curious now that I have a Capri 22 with all the trim control. The more I tinker with sails and trim the more I wonder if I am making a difference. One way to know would be a knot meter.
Is there such a thing that does not need to be through hull? I absolutely do not want, and most likely will not put a hole in it for any reason. I could use a GPS on a smart phone if I had one, but that is speed over land and does not have a direct correlation to knots per hour. Although it may show a change in value if I improved the sail trim
I have to make an admission here, don't hate me. At one time for a short while, when my kids were young and hated being on a sailboat. We could only sail as long as the juice boxes and gold fish crackers held out. I had a 20 foot IO. I have to admit that as there was a transom mounted knot meter that was not through hull. It was externally bonded to the transom below the water line and the wire ran up the transom and through a vent hole. There was an short extension that extended down and as the boat moved forward the arm would begin to raise with speed rendering a signal that was converted and displayed Knots / hour.
I have never seen such an item for sailboats. Maybe sailboats do not move fast enough to make the system effective.
Thanks,
Curt
Thanks,
Curt
