I am trying to find someone familiar with the connections on the backside of an Autohelm Knot meter, vintage from the mid 90's. On my boat I have the Knot gauge and the depth gauge mounted side by side on the cabin wall near the companion way door. The wires are run in the space between the inner and outer walls. The knot meter was starting to get 'flakey' and the display would go blank until I would tap it. I decided to check the wiring so I pulled the gauges off the wall. There are 3 wires on the back of each gauge, one wire ties the gauges together. The wires run from the back of the gauges for about 5 inches then they connect to longer wires via little plastic multi-pin connectors. These wires lead down into the bowels of the boat eventually to the transducers. The Knot meter has one its wires disconnected, or at least I am assuming it is disconnected because it has the male end a 3 prong connector. I cannot find the other side to this wire. I have even cut 3 small holes in the wall on the cabin side of this wall looking and hoping to find the other end. I can find all the other wires but not one to match up the 3 pronger.
Does anyone know if this connection is needed or is it and extra connector that would connect this guage to another gauge? Like maybe a wind speed or ???
I hate to keep cutting holes in my cabin wall looking for a wire that does not exist.
Now the symptoms are the depth gauge still works great, the knot meter is dead and never comes back to life when I tap it. It seems to me there must be another wire but I cannot find it.
Sorry for the long post but I thought someone out there might be familiar with these gauges.
