The IMPORTANT things about seacocks
First and most important, you should know where each through-hull is on your boat. If the boat ever takes on water, closing the seacocks is the first step to isolating -- and probably curing -- the problem. Second, you should never leave the seacocks open while away from the boat. (The only exception are scupper seacocks, which your boat does not have.) More than one sailor has come back to a boat sunk at dock from this mistake.There are several kinds of seacocks. Gate valves should NOT be used as seacocks, though they are appropriate for other applications, such as controlling your fresh-water tanks. Ball valves are the most common type of seacock. They come in bronze or marelon. Some boats have bronze cone valves, and these are also fine.
