Steve Cunning
I have a 37 cutter, My mast has a small kink around the spreader bars, you can see it when you sight up the mast. I have a hard time to get the mast straight, I try under sail with a full load on it on one tack then another. There is a hook between the spreader and the top of the mast, maybe I am adjusting the shrouds and stays with the wrong tension and start adjusting with the wrong ones first.Questions... Should I be concerned with the kink? Safety... Is there a sequence when applying tension on the shrouds and stays? Should I install another spreader for support and if so where?Any response would be appreciatedThanks Steve Cunnings/v Southern Comfort
