Just when you think all is well. My air conditioning(King-Air) unit, keeps blowing its circuit breakers .It's set up on a two breaker system (15amp ea.)One breaker keeps popping.I changed breakers and it does the same thing. It sounds like it wants to work ,the lites go dim and 10 seconds later the circuit pops.Lights are back on bright. The company seems to be long gone.I read in my Manuel something about pressure being equalized? Huh? It is also a reverse cycle heater and that seems to be working fine on the heat side. At least it did last year. Naturally the heater will wait till winter for it to go south on me also. This a/c worked ok last year with some difficulty. Seemed to dim the lights for 3 to 5 seconds then the a/c will get going.And the lights will brighten up. I've checked the water pump and it is fine with great water volume and I have blown air through the system for any blockage. None. Does anyone out there have similar problems with their unit and if so. What did you do? Anyone know the answer to this problem? Please...Now for the second problem. My Adler Barbour cold machine(refrigerator)unit.It to decided to head south for the season anyway.I'm sure the refer will be cold enough to freeze a soda pop this winter for sure. But, it's now when I need it. It was working fine then I noticed it was warm.??? Blown fuse(Buss GLN-10). No problem, put the spare in and pop goes the fuse. Now we are onto the last backup fuse and again pop.I move on to a 15amp fuse and this time the circuit breaker goes pop. Now I am into something over my head. Help!!! Both these units are probably original to the boat???? and its a 83 model. What do ya'll think? Any comment are appreciated Keep it up, Ctskip
