Kill switch required for all boats under 26'
Jun 11, 2004
1,734
Oday 31 Redondo Beach
Probably not an issue for most sailboats
Q12. Do I need to keep the Engine Cut-Off Switch Link attached at all times?
A12. No. The Engine Cut-Off Switch Link doesn’t need to be attached when the vessel is idling or performing docking maneuvers. The Engine Cut-Off Switch Link must be attached whenever the boat is operating on plane or greater than displacement speed
Q13. What does “on plane” mean?
A13. For a boat, “on plane” means the boat has reached a speed that moves the boat from a “displacement” mode to a “planing” mode. As more power (and speed) is applied, lift increases, and the boat, in effect, rides over its bow wave, reducing wetted area of the hull and thus reducing drag. At this point, the boat is said to be "on a plane" or simply "planing." Sailing vessels are generally not capable of getting “on plane” because of their displacement hull, whereas a ski boat, bass boat or runabout can usually achieve planing with little effort.
Likes: Whatfiero1
Feb 8, 2019
16
Caliber 33 St. Thomas, VI
Most sailboat owners own dinghys so this certainly does apply to sailboat owners. We see a lot of horrible accidents happen in dinghys that could be prevented by wearing a kill cord. Also should be noted that the kill cord should be ATTACHED to the driver not just slid on a wrist or ankle.
Nov 6, 2006
10,053
note that it is not retroactive so those of us who have older motors (I have two, a 1967 and a 1981) do not have to install an ECOS ..
BarryL
May 21, 2004
1,058
Hey,
Also note this:
Section 8316 of the Elijah E. Cummings Coast Guard Authorization Act of 2020 requires individuals operating covered recreational vessels (less than 26 feet in length, with an engine capable of 115 lbs. or more of static thrust, which equates to about 3 horsepower or more) to use ECOS “links” while operating on plane or above displacement speed. Using the ECOSL is not required when the main helm is installed within an enclosed cabin. Common situations where ECOSL use would not be required include docking/trailering, trolling, and operating in no-wake zones.
My dink has a 2.5hp engine, so I don't need to do anything. My little engine can't make my walker bay plane and the speed limit in the harbor is 5 kts.
Barry
Likes: ggrizzard
Nov 6, 2019
21
Marshall 15 Catboat Lafayette, LA
"while operating on plane or above displacement speed" ------> Looks like I don't have to worry about it with my slow catboat. If can get catboat on a plane I will be glad to hook up kill switch lanyard.
Likes: LloydB
JRacer
Aug 9, 2011
1,360
When, "on a plane" in the J/24, we always had the kill switch on". Or, was that the kill instinct. I can't recall. :laugh: Best rides ever! And, at those times, the skiers did not like the surface of the pond!
Likes: LloydB
DArcy
Feb 11, 2017
1,767
Islander Freeport 36 Ottawa
So if I had a Melges 24 with a 4HP outboard I would need to use the ECOS Link while surfing down waves with the chute up and the outboard stowed away.
RussC
Sep 11, 2015
1,603
Merit 22- Oregon lakes
Yes, but you'll need to have a cord long enough to reach into the cabin, where the motor is stowed. :p
LloydB
Jan 15, 2006
927
Macgregor 22 Silverton
Theoretical displacement hull speed is calculated by the formula: velocity in knots = 1.35 x the square root of the waterline length in feet.
3.818376618407357 to 6.88367634335026 knots for 8ft to 26ft through the water so if you can prove you were only going 3.4kt on your recorded gps you will still get a ticket if you were going against a incoming tide of 2.3kt in your 8' pram. Theoretically ;)
0
dLj
Mar 23, 2017
4,271
Here I was getting worried I'd have to put a kill switch on my oars! But while I can row mighty darned fast, getting my dingy up on plane rowing I still have not achieved beyond dreaming...
dj
  • Ha
I see this being a real PITA for the solo sailor who needs to go to the mast to reef and/or adjust the topping lift etc. Even tacking could be a problem. So motor sailing will become illegal??????
DArcy
Feb 11, 2017
1,767
Only in a Mac 26X ;)
Likes: rgranger
Mar 26, 2011
3,677
Corsair F-24 MK I Deale, MD
Read the USCG docs. All of the jokes aside, the rule does not apply to sailboats, only tenders with enough power to plane, and only then when they are above planing speed, but I wouldn't push that latter.
Likes: rgranger
Nov 21, 2012
709
Yamaha 33 Port Ludlow, WA
dj
I may have achieved this last summer. We were ashore getting pizza when we noticed that Tosca had gone walkabout. I have never rowed that fast, and hopefully never will again.
MitchM
Jan 20, 2005
1,031
thanks to our government for publishing some confusing requirements. you have to laboriously read the regs to see what's a 'covered' vessel ( 'covered,' as in: set forth in the regs, not 'covered' as in: having a cabin. ) Some boater webistes like 48North are inducing confusion by just announcing "Section 503 of the Coast Guard Authorization Act of 2018 required manufacturers of covered recreational vessels (less than 26 feet in length, with an engine capable of 115 lbs. or more of static thrust) to equip the vessel with an ECOS installed as of December 2019. Section 8316 of the Elijah E. Cummings Coast Guard Authorization Act of 2020 requires individuals operating covered recreational vessels (less than 26 feet in length, with an engine capable of 115 lbs. or more of static thrust, which equates to about 3 horsepower or more) to use ECOS “links” while operating on plane or above displacement speed." for the actual text on ECOSLs, see Engine/Propulsion Cut-Off Devices
i'm not planning to put one of these on my little 19 foot cat boat with its yanmar 10GM even though my wheel is in the cockpit. (since yans on the com-pac horizon cat 19 s have a throttle stop pull cable in the rear transom from helm down to engine , an ECOSL install could be quite interesting indeed. )
wonder if boaters can be stopped by USCG just because my ECOSL isn't visibly attached to me ?
I read this a couple of times. I think I am clear of any application, but will not know until I get stopped and boarded for inspection. Even then I suspect if the rules are confusing for us sailors to hav e17 messages, imagine how the CG feel. I can see them just stopping (hopefully not frisking) boaters and boarding just to learn what the boaters are doing about the regulation. I can hear the Chief saying. Stop them, stop them all and remind them we have rules.
Just an idea, if you want to know what the CG is thinking ab out this rule, have the CG Auxiliary give your boat a "Voluntary Safety Check". It will be a good experience.
Likes: LloydB
Mar 26, 2011
3,677
In your case the rule is quite clear that it only applies if a working kill switch is installed. If it did not come with one or if it was removed it is not required. Simple. Most dinghies powered by outboards are included because they have a kill switch.
If you read the USCG FAQ page it explains all. As for boater web sites being confusing... you really can't blame the USCG for that! Always go the the source.
USCG FAQ re. Kill Switches
Jul 27, 2011
5,134
Bavaria 38E Alamitos Bay
The kill switch retaining lanyard is a PIA on outboards, at least the portable ones <15 hp, so produced. They are not designed for actual use according to the requirement as far as I can tell, entirely perfunctory. For any dink that can plane with the hp needed the operator needs to move fwd for proper boat trim and use an extension from the OB throttle. By the time the operator gets that far forward on the short lanyard it is pulled from the switch if anywhere but on the operator’s wrist (maybe there even), shutting down the engine. So now you need to make one up yourself. A long one, maybe 3 to 4 ft, that will no doubt sooner or later get fouled on something between operator and OB, etc. The short OME lanyards are “useful” only when they are not required, IMO. That is, when the operator is sitting near the engine on a dink with low hp OB that usually will not plane it, especially with two aboard.:doh: Say, an 8.5 ft inflatable, air floor, with a 2 to 5, maybe 6, hp OB, etc.
They might be functional as intended on a boat over 10 ft LOA heavy enough to keep its own bow down while planing, such as14-ft whaler, etc.
