Keystock for coupling/prop shaft
Todd Canfield
I have a 78 hunter 30 with a yanmar ysm 12. I am wondering if anyone knows the key stock size for teh keyway and the size of teh set screws for the coupling/prop shaft. Thanks to all in advance. Todd
Todd Canfield
Key for Coupling
I have tried as 1/4" keyway and the coupling shows alot of slop. I then tried a 5/16" keyway and it is a little over sized. I went to the boat last night and tried a 7mm and it seems to be the proper one. I don't know if the keyway has worn or if hunter used some metric hardware. Thank you for your response. If I don't get this fixed today I feel like I'm going to sink it, or call it a summer home. Best regards, Todd
Todd Canfield
Key stock for coupling
Henry, Thank you for the information. After further inspection I had found that the coupling was damaged. I had torn the coupling apart and on the mating side of the coupling the key does measure 1/4". Thanks agian. Regards, Todd
