wow sumner, I didn't realize they gave you such a hard time on the wag bags... might be a non USCG approved issue. ?
OTOH, the dumping of a pottie could be a real problem... since they don't want you using a toilet.
http://myfwc.custhelp.com/app/answe...sion/L3RpbWUvMTM0OTkyMzEyNS9zaWQvMy1tZU9wOGw=
Boating - toilets, sewage and no discharge zones.
Answer ID 1084 | Published 12/24/2002 01:43 PM |
Updated 09/07/2012 02:00 PM
Does my boat have to have a working toilet? What are the regulations for discharge of sewage from a vessel? What is a "no discharge zone"?
The following is part of Florida Statute 327.53 relating to have a working toilet on board when in state waters. To view the Statute in its entirety, visit
http://www.leg.state.fl.us/Statutes/index.cfm:
"(1) Every vessel 26 feet or more in length which has an enclosed cabin with berthing facilities shall, while on the waters of the state, be equipped with a toilet. On a vessel other than a houseboat, the toilet may be portable or permanently installed. Every permanently installed toilet shall be properly attached to the appropriate United States Coast Guard certified or labeled marine sanitation device.
(2) Every houseboat shall be equipped with at least one permanently installed toilet which shall be properly connected to a United States Coast Guard certified or labeled Type III
marine sanitation device. If the toilet is simultaneously connected to both a Type III
marine sanitation device and to another approved
marine sanitation device, the valve or other mechanism selecting between the two
marine sanitation devices shall be set to direct all sewage to the Type III
marine sanitation device and, while the vessel is on the waters of the state, shall be locked or otherwise secured by the boat operator, so as to prevent resetting.
(3) Every floating structure that has an enclosed living space with berthing facilities, or working space with public access, must be equipped with a permanently installed toilet properly connected to a Type III
marine sanitation device or permanently attached via plumbing to shoreside sewage disposal. No structure shall be plumbed so as to permit the discharge of sewage into the waters of the state.
(4)(a) Raw sewage shall not be discharged from any vessel, including houseboats, or any floating structure in Florida waters. The operator of any vessel which is plumbed so that a toilet may be flushed directly into the water or so that a holding tank may be emptied into the water shall, while the vessel is on the waters of the state, set the valve or other mechanism directing the sewage so as to prevent direct discharge and lock or otherwise secure the valve so as to prevent resetting.
(b) All waste from Type III
marine sanitation devices shall be disposed in an approved sewage pumpout facility.
(c) All waste from portable toilets shall be disposed in an approved waste reception facility.
(5) Every vessel owner, operator, and occupant shall comply with United States Coast Guard regulations pertaining to
marine sanitation devices and with United States Environmental Protection Agency regulations pertaining to areas in which the discharge of sewage, treated or untreated, is prohibited."
All marine sanitation devices must be U.S. Coast Guard Approved. All waste from portable toilets shall be disposed of in an approved waste reception facility. Restroom toilets are not approved reception facilities. Some of the chemicals used in portable toilets do not break the waste down to acceptable levels nor do they kill disease-causing organisms. Marinas are encouraged to use funds from the grant program to install approved waste reception facilities at their site.
Since October 1, 1994, boaters are prohibited from discharging untreated sewage into fresh or within coastal salt-water limits. Coastal limits are 9 nautical miles on the Gulf and 3 nautical miles on the Atlantic Ocean. "No Discharge Zones," also known as NDZs, prohibit boats from discharging treated or untreated sewage into water bodies. In these waters, a "Y" valve has to be closed. The NDZs in Florida are: Destin Harbor, the City of Key West waters, and state waters within the Florida Keys National
Marine Sanctuary. You can view the complete Federal Register notices for each of these areas at
http://www.epa.gov/owow/oceans/regulatory/vessel_sewage/vsdnozone.html#fl. In all states, rivers, lakes, and reservoirs without interstate navigation and where entry or exit by boat is not possible are considered NDZs. This prohibition includes treated sewage from
marine sanitation devices. It does not apply to gray water from showers or sinks, only sewage. For more information about
marine sanitation requirements for boaters, please see the Florida Department of Environmental Protection's web at
http://www.dep.state.fl.us/cleanmarina/cva/.
they do have a contact us link:
http://myfwc.custhelp.com/app/home
