Key and starter button switch not working
Dec 7, 2013
8
Hunter 33 Grosse Pointe Park, MI
I have a 1981 33' Hunter and my key and starter switch aren't working. Any help on where I can pick on e up or a new control panel?
Johnb
Hunter 37-cutter Richmond CA
If that is anything like the wiring on my '83 HC37 there is a fuse mounted on the engine that is in the feed to the control panel. You may want to check that. (It also provides an easy to access test point for power going to the panel)
Sep 19, 2009
23
Hunter 29.5 Honolulu
I had a similar issue. I posted a topic on it. I would first check the fuse. It's easy to find. It's next to the starter. I had a loose connector. It took 10 seconds to fix. If the fuse is blown, replace it but considerate it a sign that something else is going on such as a short somewhere in your system.
Best of luck!
May 24, 2004
7,237
CC 30 South Florida
Check the wiring harness between the control panel and the engine. With time and hull flexing they tend to chaff where they come in contact with the fiberglass around bends and may have cut clean through the power wire. Just another possibility.
