I
Ike Cook
In my 1974 H25, I have the original Alcohol Stove. Last season it worked great. This year, the right burner continually leaks alcohol, causing major flare ups, loss of pressure, and inability to use the left burner. I've tried to tighten the packing nut, but it doesn't seem to work. If I take the cap off, I can watch alcohol squirt out of the little pin hole, when the control valve is OFF.Has anybody tightened this control? Any suggestions, short of buying a new range top are appreciated.Ike'Freebie'
