Kenyon 550 tank valve
76
33 Hunter Cherubini Sardis, MS
Can anyone point me in the right direction to find the replacement t shut off valve for the pressurized tank on our 550 stove/oven. I would prefer to just pull the guts out of the valve and swap out the assembly versus remove the whole valve and re-weld or solder a new one in. Kenyon advised they don't sell the parts anymore for the tanks. He said that you should be able to find it at Home depot or Lowe's, but when I went there they had nothing even close and of course the guy working there had no clue about plumbing fittings.
Edit:
To clarify what valve I am talking about, it's the valve at the top of the tank that the hose connects onto which shuts off the flow of alcohol to the stove.
Aug 14, 2011
76
To follow up, the fittings are actually air type fittings and I was able to replace them through a company in Memphis called FluidAir.
The next question if anyone can answer is:
The cap on the alcohol tank, which is separate from the stove on the 550, bleeds pressure off immediately. Can anyone put me in touch with a company that can offer a replacement cap or rebuild the cap? This is a royal pain to get back up to speed, but so much cheaper than buying a whole new unit.
