" The salt we add to the ice creates salt water which is actually colder than ordinary iced water. In other words, salt water has to get colder than 0 degrees Celsius (°C) before it will freeze. In this case, milk is like regular water and freezes when surrounded by colder salt water. This allows the ingredients to mix together to make ice cream.
The salt works by lowering the melting or freezing point of water. The effect is termed 'freezing point depression'.
When you add salt to water, you introduce dissolved foreign particles into the water. The freezing point of water becomes lower as more particles are added until the point where the salt stops dissolving. For a solution of table salt (sodium chloride, NaCl) in water, this temperature is -21°C under controlled lab conditions. In the real world, if you were to add salt to a frozen footpath, sodium chloride can melt ice only down to about -9°C.
Since salt interferes with ice crystals forming in water, adding salt to water effectively lowers its freezing point. This is why the oceans don't freeze, even when the temperature is below 0°C. The ocean, which is about 3.5% salt, freezes at approximately -2°C .
For saltwater that's as saturated as it can possibly get (i.e. there's no way to dissolve any more salt in it no matter how hard you tried), the freezing point is -21.1 °C . This is when the saltwater is 23.3% salt (by weight).
Applications
In colder parts of the world, salt is often used on footpaths and roads to melt ice and snow. Salt is used on roads and walkways because it is inexpensive and readily available.
When ice melts, it absorbs heat energy from its surroundings. When you add salt to ice, the rapid melting of the ice can cool the ice and water to below 0°C. Before refrigeration was invented, ice and salt was used to produce the rapid cooling needed to make ice-cream. "
Applications
