Keel
11
2 oday27 Richmond calif.
Hello, I'm new to this site,just found it today.
I had this boat six months .
Anyway my first question is can anyone tell me how to inspect my keel attach bolts and where would they would be found on an 1976 ODay 27 . nothing is visible in the small blige.
thhanks
Tony
DannyS
May 27, 2004
933
Beneteau 393 Bayfield, Wi
The 27 does not have keel bolts. I believe the ballast is encapsulated in the fin keel and then glassed in place.
I used to own a 27 and looked for the bolts only to find a smooth floor in the bilge.
Jan 24, 2005
4,881
Oday 222 Dighton, Ma.
The O'Day 27 has a poured lead keel. One of the guys in my club owned one up to a couple of months ago, and he told me that the keel is on that boat is poured.
Dec 8, 2006
1,085
Oday 26 Starr, SC
Keel question
Thank you for the Keel bolts reply
Tony
Tony,
But you still have the seam question.
Consider this, on many production sailboats the keel was made separate from the hull and the merged together in the production process. When the "keel was poured" does not mean that it was poured directly into the FRP part of keel.
The lead was poured into a mold. Then was glassed into the keel cavity. So, the seem might be where the lower part of keel was merged to the hull part when the lead insert was glassed into the whole?
I do not know that the O'Day 27 was made that way, but do know that technique was used in making other keel boats. So, for what it is worth...
That same technique was also used in fabricating stubby keel sailboats with centerboard. That is the keel appendage to the hull was fabricated separate from the hull early in the process and glassed together later.
Sometimes there are/were flaws in the merging process. Flaws result in leaks, but since flaws were small, keels did not fall off. The flaws were enlarged enough to insert resin putty into and fixed. This repair process can be seen today in yards doing bottom repairs.
Ed K
26
Jun 2, 2004
1,952
Oday Day Sailer Wareham, MA
I just checked the 1977 O'DAY 27 brochure (photocopy) that I have and the hull and keel are in fact molded together as one piece, no keel bolts, no seam. That should relieve some worrying?
