Keel replacement
160
Hunter 27_73-83 Harrington, Maine
Just when you think you thought everything thru you realize you havent. Found a fin keel to replace my shoal draft and it appears the keelbolt dims may be slightly different than my boat, by as much a 2". Does anyone know what the process was - maybe the factory drilled the holes to fit each keel? Anyone ever plug keel holes?
Jun 2, 2004
425
- - Sandusky Harbor Marina, Lake Erie
Oh dear!
All our previous discussions have assumed they were the same! I'm pretty sure that included the experience of one or more members who did the same swap! Do check the archives. David Lady Lillie
Alan
Jun 2, 2004
4,174
Hunter 35.5 LI, NY
None the less....
.....the keel bolts are not really important to holding the keel on. The real structural support comes from the 3M 5200 bonding agent. If a couple of bolts can be used just to hold the location while the 5200 sets up, you're in business.
